I was keeping this to fit in a kit when I got one but I am going to let it go to help fund a car after being let down on my bike sale.
C20xe redtop complete engine
This was in a corsa originally I have driven it and its seriously quick runs well no issues or smoke etc.
It was sold to me as having-
Newman mid rally cams
Omega pocketed pistons
QED rods
Arp Bolts
I have not seen inside the engine so cannot verify it but I have no reason to disbelieve.
It definitely has-
Non Dizzy engine with coil pack and leads
Twin Mikuni Carbs on a proper manifold with k&n box filter
Mbe ECU with full engine loom
Starter motor and flywheel
I have with it (not fitted)-
Brand new Retro Power Manta big wing sump and new cork gasket.
Retro Power modified pick up pipe.
New spigot roller bearing
I will accept £1800 for it sorry no offers, if I took it apart and checked above parts would be a lot more but haven't got the time
This should be around 195bhp
I also have a 4 speed Quaife Pro Type 9 Box with quick shift
It also has a bellhousing for C20xe to type 9 fitted with clutch arm
The ratios wont be for everyone as it is a short oval set up with long first gear and what is almost another 2nd gear instead of 3rd
these can be changed to suit.
1st - 2.040 long gear
2nd- 1.69
3rd - 1.54
4th - 1.1
The gear kit alone is £1000 but will take £900 for the box or £2500 for the complete package.
in Huddersfield
u2u for viewing etc
Should be a good package for someone! Possibly a sprinter
