Hi everyone,
Having a bit of a workshop clean up, what started as a pair of seats is now turning into a full blown clear up!
Pair of Cobra Roadster 7 Seats
One in very good condition, other I still need to drag down off the top shelf in the garage, seem to remember it had a few small holes at the base
(will confirm this evening). Black, with yellow 'Cobra'. With harness holes, and seat runners.
Seat 1: excellent condition, could do with a clean but that is all. Photos:
Seat 2: ok condition, small paint mark on front of the seat pad, tear on the RHS side support, small holes on the LHS Seat pad side. Photos:
As one is a bit damaged I've reduced the price to £180 which is still far cheaper than buying just one!
Pair of Fibreglass Seats
Brand New (un-drilled but a bit dusty and a few scuffs) in gel coat primer.
Dimensions:
Width (Inner): 32cm
Width (Outer): 37cm
Width Across shoulder supports: 47cm
Height (from floor to top of back): 85cm
Length (from very back at the top to the front): 81cm
Photos:
Price £40 for the pair.
Carbon Fibre Cycle Wings
Change of plans, going from loads of carbon to loads of aluminium. Pre drilled with a few spider cracks around the holes, few little bubbles here and
there but otherwise in good condition. They have a bit of a twist in them, but will straighten out once fitted.
Width: 20.5cm
Length (straight line front tip to rear tip): 60cm
Will get some better measurements up later incl holes.
Photos:
Price £50.
Quick Release Steering Column
Spa quick release steering boss welded to a steering column, complete with a 3 hole to 6 hole (OMP, Sparco, Momo, etc) steering wheel adapter &
OMP horn button.
Total length (incl boss): 77cm
Keyway: starts at 18.5cm from wheel face, ends at 23cm.
Bottom splines: 14.25 x 36 (Sounds mk1 escort).
Photos:
Price £50.
Collection from Rye in East Sussex.
Payment: via cash on collection.
Swaps or Part Ex: yes after harnesses (4 point with aero buckle, bolt in lower mounts, ideally in ticket) Stack pro water temp or oil pressure gauges,
Stack speedo, interested in anything crossflow, or tig welded header tank or washer bottle.
Offers: always open to a sensible offer.
You have a U2U on the cycle wings
U2U re FG seats.
My car has 185/60R14 (according to web 577.6mm, haven't measured properly, busy day!) and they looked pretty good, I've put one on my spare
with an inch thick spacer between tyre and wing to give you an idea what they look like:
Wings now SOLD everything else still available.
Price Drop:
Cobra Seats: £150
Fibreglass Seats: £30
Qr steering column: £40
Wings: SOLD
Fibreglass seats are now gone.
Cobra Seats down to £130 (I've looked in to posting them and they wanted silly money, so collection only)
QR Column £30
U2u sent about seats
All that's left is the Cobra seats, make me an offer as I want them gone!
£100 for a pair of Cobra seats, collection only.
Still available, I will be going to Kingsfold near Crawley this weekend or Leamington Spa area on the 18th of October, you are welcome to collect from there instead.
