FS My old RGB chassis, raced for 4 years, front end is damaged and needs replacing due to a little off at Cadwell in the last race (the infamous
steering joint failure).
Started life as a vortx chassis, then had the new GM2 bodywork fitted last season. I had several podium finishes with the car.
The roll cage was fitted last year at a cost of £400.
I've spoken to Marc at MNR and if required he will do the work to repair the front end (at a cost obviously
, he also mentioned that he has
some old Vortx bodywork that may be available.
I'm after £350. Pickup only
Chassis1
Chassis3
Chassis4
Chassis5
Chassis6
