Carbon RAM air intake to cut down induction noise on track days.
£200 delivered to UK will post abroad at cost.
dimensions :
Fitting plate is blank. Airbox has no holes drilled in it either.
So there is only the air filter hole cut in it
Yes, there's the hole at the bottom which bolts onto the alloy plate, and the ram air hole which hangs out the bonnet.
There are no other mounting holes (it's new)
This is what it's intended for...
Same as this and a very nice airbox, I fitted one to the striker see pic,
raw striker airbox
[Edited on 6/1/15 by INDY BIRD]
dimensions :
I still have the mould but it’s a bit knackered.
I can certainly make one but can’t guarantee it will be mint.
Might also be interested, dependant on price. Either carbon or fibreglass would be fine, if fibreglass brings price down even further.
I will revert with prices...
They look great. Also interested in the cabbage cannon!
Do they fit over the air filter, in which Case would I need a certain one? Thanks!
Excellent, does the cabbage cannon including heat or movement seeking sights? 😁
I’m interested - pricing and availability please.
Craig
I'm also interested in this
