Intercooler
Sierra - 15/1/15 at 02:43 PM
Just bought this off a member but unfortunately it's not going to work out with my setup
Never used and comes with some silicone joiners and pipe work. Also fits in the nose of a 7.
Core size is 320mm x 300mm x 80mm
Overall size is 300mm x 355mm at the bottom and 470mm at the top where the outlets are.
Outlets are 70mm.
Just want back what I paid £65.
[Edited on 16/1/15 by Sierra]
welderman - 15/1/15 at 03:42 PM
IS THAT POSTED ?
Sierra - 15/1/15 at 06:10 PM
Will have to look into how much postage would be.
coozer - 15/1/15 at 07:10 PM
Why doesn't it fit mate? It was mounted under my nose no problem with a polo rad.
Sierra - 15/1/15 at 07:18 PM
It does fit under in the nose with the radiator but I need the outlets in a different position for my setup. Like a numpty I did look into this before buying.
Sierra - 15/1/15 at 07:29 PM
Think it will cost about £10 to get it posted so will do it for £70 posted.
luke2152 - 16/1/15 at 08:59 PM
Could you give some accurate dimensions? And does it have any mounting points
Sierra - 16/1/15 at 09:09 PM
Hi I've added the dimensions. It hasn't got mounting points on the cooler.
Sierra - 19/1/15 at 08:30 PM
Now £65 delivered!
luke2152 - 20/1/15 at 11:32 AM
I might give you a bell in a few weeks. Its so borderline between perfect and too big and I've ordered a bigger radiator and have to make sure it will all fit. If it was £50 delivered I'd take a punt on it.
