Hi all
I've got a few bits knocking around my garage that I need to move on. All prices plus postage-
Ford Thermostat housing -
£10 (new)
Ford Thermostat housing and cap -
£10 (used but in good condition)
Ford dual circuit master cylinder £15 (new)
Unbranded dual circuit master cylinder (Ford pattern) £10 (new)
Pair of front and rear plates for K&N filters for twin 40s (may fit 45s too - I can measure if you want) - £20, Used but in very good condition
Large K&N filter - good filter (backplate has been butchered but not by me!) - easy to fix with a sheet of ali - £20
New water pump but I have no idea what fits! £10
Wyn
[Edited on 25/1/15 by lsdweb]
u2u re Ford dual circuit master cylinder £15 (new)
I'll take the stat housing with the cap please.
U2u on its way.
u2u on the way.
Does anyone have an idea of which car the first, yellow, master cylinder is?
I have a similar one, but don't know where its from!
What carb is the large K&N from?
Hi alland3851
I don't know which carb and as the backplate has been modifed it will need a bit of modification anyway.
Overall dimensions are -
Width - 225mm
Height - 135mm
Depth - 70mm
Ta
