Arays 15inch x 6.5 Alloys ET15, ford fit (4x108), in great condition. £150 collect from Bristol, can courier at your expense.
Wilwood Powerlites & Arays
Castle Combe
Arays wheels
Oooh thier a bit nice... Et 15 you say, WI have to check mine on the fury on Wednesday when I'm back home. I'm due in Weston so past ypur way but not for a few weeks. If they are the right offset would you ind holding them ?
No issue with holding them, if you are uncertain on the offset have a look at this tool: Will They Fit...
Thread hijack and free bump.
Do you mind weighing them?
I have just removed mi donor allows @ 17 inches and they weighed shy of 10 kg each.
I bought aftermarket alloys which are lighter but looking to change for 15" rims.
No intent on buying but just curios what a 15" stick alloy weighs.
Sorry for spelling mistakes. It's a b!txh to delete half a post to correct
Thanks in advance
Angel Acevedo
Thanks in advance
Angel Acevedo
Knew it!!! I bought 17 inches but regret it big time. I'm having a hard time getting 15 inch on 5 X 114.3 with something like 73 mm center bore
diameter...
Thanks for your time and consideration
Good luck with the sale
AA
Still got these?
Price drop & a bump.
Now £130.
