Having a garage clear out after a complete rebuild on my Westfield please ask for any photos if require and i will upload them
Carbon effect front cycle wing each have 6 holes for mounting £35 Posted
Propshaft off a 4 speed box 76CM LONG small english flange to a 20 Slined yoke £50
A pair of seat runner (1 seat) £15 Posted
Uprated Type 9 to 20xe clutch only done 200 miles rated to 200 BHP £100 Posted
Brand New 3m -12 hose and 4 elbows and 2 straights £50
Brand New 5ltr 10 40 Millers running in oil £20 Posted
Brand New Round Carbon Effect housing and fog light £15 Posted
Brand New 8ft by 4 ft carbon effect sheet from Playskool £60
GoTech Pro X ECU runs upto 8 cylinders - Has no loom but most all plugs needed and mapping software £175 Posted
Lumination Ecu with loom and distributer etc everything needed to connect to throttle bodies £150 Posted
CWP removed from my 1991 English axle Westfield 3.89 in perfect order £90 delivered
Yukspeed 20xe shallowed wing sump and modified pick up works perfectly but have decided to go drysump for extra protection £125 Posted
13' Caterham Minilite wheels wrapped in SG R888 Fronts 185 60 between 3.5-4 MM, Rears 205 60 2.5-3mm. Painted in high metallic black fronts have
no marks inside are not perfect but never bother me as you can see them. NSR has a few extra weights than normal to balance but balance fine and cant
feel anything on the car £300
Brand New Alloy 42mm High Flow Civic raditor 32 mm Hose connection same as this http://www.ebay.co.u...=item232c83242e
have the same fitted on a 200+ 20XE Westfield and works perfectly on road and Track £60 Posted
Located in St.ives Cambs
[Edited on 10/9/15 by drummerdrum_uk]
Pm sent regarding Yukspeed sump.
Matt
U2U sent re: Rad
Tony
Hi,
This may be a nubi question, but.
How universal are the seat runners? I have a pair of GRP/carbon race seats and putting them in an MNR.
Stuart
