Hi All
Does anyone want to sell a clutch alignment tool for a duratec? I have the kind that grips the clutch to the clutch-plate, but I would prefer the one
that inserts into the spigot bearing and clutch.
Similarly if you have a flywheel locking tool that you're up for selling, I'm interested. I have a universal flywheel locking tool, but it
doesn't fit my flywheel.
Mark
I manufactured one from a turned nylon rod with a tapped hole in the end,. I can do the same for you if that helps,.
I'd just need the dimensions,. od/length for the spigot, and then the same for the clutch...
I think I have one £10 including post
Hi KJ, Howard
I'm interested in both. I'll opt for KJ's option first just because it may be easier all round. I also like the idea of a custom
machined one. KJ, can you let me know what model it to is please.
Many thanks for your help.
Made my own locking tool.... fits in place of the starter motor.....
Can send you a pick if you want to makes your own
