Fed up of "blowing" your throttle bodies off.
Fits gen 1 head/throttle bodies, held in place with grub screws and simply can't move once fitted.
Looks much better than 4 short hoses & 8 jubilee clips also allows quick removal as & when required.
£150 delivered.
I also have a fair few busa bits that I've accumulated, ecu's, throttle bodies, complete gen 1 engine reputably good bought as a spare but
never used, a 1441cc engine with 1 x broken rod & "small" hole in crankcase, it as Kent cams, verniers, not stripped but head &
gearbox should be sound, it as a gen 2 crank in it that when built was new & unused, again the crank should be sound, power commander mapped for a
1441 engine.
Any interest in any of the above fire away.
Somebody sent me a u2u re engines above, I hit delete by mistake, if it's you please message me again
How much are you after for the 1441 engine?
thanks,
Dean
