Evening all... The time has come to sell the car...
Started build in 2006
Car IVAed in 2013 correctly with screen fitted at the time of IVA.
Luego Velocity XT with 4500 Smiles miles with full build documentation. age related plate in line with donor.
Black Panels with Aluminium side panels.
No expense spared
2.0 ST 170 with active VVC. DTA ECU, Jenvey fuel injection throttle bodies, Pace dry sump system. Engine when fitted to the car had only done 50miles.
Currently about 200 BHP.
Gearbox is A rebuilt BGH Geartech type 9 With long first gear and hydraulic clutch conversion with ally bell housing.
Dash is Racetech with data link to DTA ECU fitted to a carbon mod dash.
Brakes Wilwood fronts with HiSpec rears with integrated hand brake.
Rear diff is a Sierra LSD.
Seats are Tillet full carbon with alcantara pads. These are the same as the high end Caterham Carbon buckets supplied by Tillet.
Body has a number of carbon panels including dash and bespoke carbon nose with nasa duct cold air induction. Airbox is also carbon.
Chassis before the car was build was stripped from new and hot zinc sprayed then powder coated grey and injected with waxoyl.
Difficult to put a price on the car but if interested drop me a PM and I can send some pictures and we can discuss a price.
U2U Sent
