Hi all.
I have a large pile of 919 Fireblade parts for sale. These have come off my ex (Colin Chapman) RGB Fury or were part of the large spares package. The
car is having a different engine package so all parts are for sale.
Everything is located in South Wales - we're not locked down but appreciate others are. I could pallet parts up for courier collection.
Prices are negotiable especially if you want to but a few things.
1. Low mileage engine with standard sump, carbs, starter , ECU, coil packs, reg/rectifier, thermostat. A bundle of wiring of some sorts (the
wiring on these is simple). £550
2. Ex AB racing engine with synchro fault (believed to be 3rd gear). £200
3. Ex AB racing engine with synchro fault (believed to be 4th gear). £200
Carbs and mounting rubbers x 2 @ £70
AB Racing alloy paddle shifter fitted to steering column top half, complete with cable bracket and gearbox / engine bracket. £100
AB racing billet sump. £100
Shortened stock sump £50
Tony Law air box complete with clamps etc. £100
Tony Law manifold and exhaust. £125
Spare manifold and exhaust. £75 https://i.imgur.com/duKu0Ezm.jpg
Engine mounts to fit engine into Fisher Fury (but will probably work in other BEC chassis.) £75
Spare ECU £15
Fireblade Dash x 2 @£50
Electric reverse mechanism (was on live axle car but could be adapted for IRS rear) £50
Sprocket adaptor looks unused £40
Sprocket adaptor used £25
Prop £100
Oil cooler adaptor and braided hoses. £25
Photos are all here - https://imgur.com/a/X6OmWeZ?nc=1&nc (sorry I can't attach them to posts anymore).
Wyn
[Edited on 16/11/20 by lsdweb]
Hi there interested in the paddle shift and brackets
Would you take a trade for my Aim mychron 3 plus for them?
Also do you have a floor mount pedal box that you would sell?
Regards Craig
[Edited on 15/11/20 by Craigib76]
Thanks Craig
No swaps sorry - I have a Race Technology dash .
Wyn
Regards Craig
Do you have any other images of the paddle shifter mainly how it mounts on to the steering column
Regards Craig
Regards Craig
It has brackets welded to the column Craig. I'm including the column (but not the inner so you'll need one - I think it's standard
Sierra).
Yes mine is std Sierra as well so should not be a problem
Still interested in it
Will let you know 100% in a bit
Cheers Craig
Hi
What diameter is the silencer on the exhaust and do you know what Db if was on track?
James
Originally posted by jamiepearson69
Hi
James
Regards Craig
What’s the difference between the AB racing engine and a standard one?
Airbox, 1 dash, prop, prop adaptor, paddle shift and oil cooler stuff all sold / promised.
U2U sent
Any pictures of the electric reverse fitted Wyn? I'm using a live axle so I might be needing one.
Pete. It took me a while to work out but it fits at the gearbox end! I'm going to refit it when I get a chance to get some photos done.
Nice one, keep me posted. Cheers
Hi
Is the engine package still available, or has it now sold?
Is the airbox still available? If so please PM me.
The engine package has been sold (with the car).
Sorry.
Hi
