Some stuff that is surplus to requirments. Used but in good condition.
Pair Hella indicator & side lamps
E1 on both clear and amber lenses, includes bulbs.
Perfect for the square lamp look.
£ 7 inc postage
hella indicator & side lamps
Land Rover Defender reverse and fog lamps LESS lenses. red and clear
lenses can be purchased separately. Good condition, one has bulb, other hasn't. The muck on the reflectors is just that and can be wiped away
if desired, no extra charge for this.
LR rear lamps
£ 5 inc postage.
Ford brake test switch, including bulb and connector.
£ 1.50 inc postage.
ford switch
Dashboard warning lamps
As sold by Europa Spares for £ 3 each (not inc VAT!) "Quality Chrome bezel plain warning lamps", 12 mm hole, WL3001-4
With bulbs and spade tag fittings.
Two red (battery and oil), two green (L and R indicators) and one blue (high beam warning).
One other red lamp that is not the same for brake warning.
Purple toothbrush is not included nor is the worktop.
£ 6 inc postage.
[img][/img]
