Just starting to clear out some of my spares..
Should be at stoneleigh....
I have a pair of 7" long 1.9" diameter springs 400lbs... In black.. both have been used, but will work fine.
A Pair of Swept wings in blue. Undrilled, un molested...
How much for the teddy and the bed?
its the guest bedroom.....so I can rent the tedybear and the bed on a nightly rate.....the rate depends on how hard you work in the garage, what you
do with the teddy is up to you
[Edited on 14/4/08 by tegwin]
Originally posted by tegwin
its the guest bedroom.....so I can rent the tedybear and the bed on a nightly rate.....the rate depends on how hard you work in the garage, what you do with the teddy is up to you![]()
