No small garages for sale
but here are some bits I no longer need.....
First up a Bailey morris propshaft, never used. Closed length 740 mm, max open 790mm. One end PCD 96 (I think!) suitable to attach to Sierra diff,
the other PCD 90 (was designed for an omega 'box, but turns out there are loads, and this didn't fit the gearbox I had). I guess this end
could be changed fairly easily to mate up with something more useful.
Next is a sytec injection compatible fuel pump, not sure of the flow rate - but suitable up to 350bhp (!) according to Dax. Used for 60 miles (now
switched to bike carbs). I put too much thread lock on the thread of one of the terminals, and now can't get the nut off - don't want to
damage it, so it and the electrical connector are still there!
Last is a set of Dax Rush SVA bars, probably very model specific, but worth a go!
All available for any sensible offer (mostly want rid - so don't be embarrassed!) + postage at cost (or collect from Southampton area)
Ta
Chris
[Edited on 20/5/08 by chrsgrain]
u2u on prop
first dibs on the pump please .
Second dibs on the fuel pump!
