Hi Guys,
I have a Facet Red Top pump with fuel unions and electrical connector.
As found here; Facet Pump @ Demon Tweeks
Note that the unions cost extra.
I've tested this pump and will guarantee it's working.
Ideal for carburettors or can be used to feed a swirl pot for a fuel injection system.
I'm looking for £30 + P&P
[Edited on 4/8/08 by JAG]
[Edited on 8/8/08 by JAG]
What psi range is it, I'm looking for a 3psi one?
According to the Speedshop UK website
Facet Red fuel pump features include:
12 Volt negative earth
Operating temperature -60 to 43°C
Flows 35 Gallons per hour
Pressure between 6.00 and 7.25 psi
Lift ability of 0.6m
1/4 NPT inlet and outlet
Suitable for vehicles up to aproximately 240 BHP
thanks Justin, will pass on it..
this will pump at a lower pressure with a regulator wont it?
if so i'l take it
cheers
james
Yes ideally these are to be used with a Filterking after it to get correct pressure for carbs.
auzziejim; you've got U2U.
