Has anyone used a lsd from a 2. 9 Sierra in a kit car. I was just wondering if it might be to tight and make the car understeer.
Just had mine tightened up by changing the fluid as it was swapping traction from side to side in a straight line, this was wheel spinning up to about 50 though. Lots better now but, a standard lsd is a lot better than an open one. Will not cause you to oversteer at all, i did quit a few track days on standard lsd with out a problem
Thanks for that will give me something to do fitting one over christmas hol
