Charlie_Zetec
| posted on 14/9/09 at 01:33 PM |
Sierra switches and steering coweling
Well I made the jump at the weekend, and chose to take the angry grinder to my steering column. Thus, I now have a shorter column similar in style to
w Westfield with just the boss and snap-off section protruding past the dash.
As such, I do have the old Sierra column switches and coweling surplus to requirements. Having looked at it, the screw hole at the top where the
hazard switch sits has been superglued at some point (was like that when I bought it), but it hold to the column fine; apart from that, all looks
good.
Before anyone asks, there's no loom with it, as I've ordered a bespoke loom from Premier Wiring, and was going to crimp-terminal and
heatshrink the ends where necessary. Sorry!
I've seen people ask silly money for the bits, but I think £20 posted is reasonable, yes?
Any takers, please U2U me.
[ PS - I'm away on business until late Wed eve, but can post on Thursday so should get to you by the w/e. Or collection possible from Essex
area if desperate.]
AdrianH
| posted on 14/9/09 at 04:40 PM |
Can you let me know if it is for the adjustable or non adjustable column.
Also if the Hazard switch is round on top of the cowl?
Adrian
Why do I have to make the tools to finish the job? More time then money.
Charlie_Zetec
| posted on 14/9/09 at 09:44 PM |
Items came off the adjustable column, although I'm not sure what the difference is, as the adjuster lever is on a separate unit. Care to
enlighten me?
And yes, the hazard switch at the top of the left hand indicator unit is round.
Hope this helps!
AdrianH
| posted on 15/9/09 at 06:43 AM |
The cowling I had was for an adjustable column, so had a big slot underneath for the handle, I am now after one without the slot..
The different metalwork in the brackets meant the clamp inside the cowl was slightly different diameter.
I believe although not seen one that there were different versions of switch gear, some possibly every early had a squarish hazard switch, but can not
confirm that.
Adrian
