Minicooper
| posted on 20/1/10 at 06:56 PM |
New Old Stock Cortina Uprights, 7.5 LSD Diff, Machine Mart Pipe Bender
Hello all,
I have some new old stock cortina uprights, complete with hubs, disk, calipers, etc. They are not reconditioned they are new, the calipers maybe
reconditioned I'm not sure about that so I will say they are at least reconned if not new old stock as well. Disks are new with very light
surface rust, new pads pins and wheelnuts
I'm not sure on price but since tatty rusty complete sets seem to go for around a hundred these days
u2u me with an offer if your interested
I also have for sale a 7.5 2WD 3.62 lsd believed to be from a low mileage Sierra Cosworth, it has the 108mm lobro outputs, lobros, shafts not
included, I have taken of the the rear mount on the cover so this will suit a kit car but not the standard sierra install unless you can find another
rear cover.
There is no slop in the diff and when I took of the rear cover the oil was a crystal clear redish colour with no bits in the oil
£150
Clarke CHV12 12-Ton Hydraulic Pipe Bender
I have one of these pipe benders for sale
http://www.machinemart.co.uk/shop/product/details/chv12-12-ton-hydraulic-pipe-bender
Just to be clear this is a PIPE bender because it is supplied with PIPE bending formers, not suitable for thin stuff. £70
I'm based in Chandlers Ford, Hampshire items are probably pickup only due to weight
Minicooper
| posted on 22/1/10 at 10:36 PM |
Some pictures, the disks look a bit mankey but they are only very lightly rusted
Minicooper
And another one
daniel mason
| posted on 22/1/10 at 11:03 PM |
u2u
R1minimagic
| posted on 23/1/10 at 10:17 AM |
Will you throw in the spices too?!
If we knew what it was we were doing it wouldn't be called research would it!
Valtra
| posted on 25/1/10 at 05:31 PM |
u2u re. calipers
"If it looks like it works and it feels like it works, then it works"
ChrisW
| posted on 25/1/10 at 06:43 PM |
Does the pipe bender weigh more than 25kg?
Chris
Minicooper
| posted on 25/1/10 at 08:09 PM |
Chris I will check, it is a heavy lump that's for sure, will let you know
Minicooper
| posted on 25/1/10 at 08:10 PM |
Hello Dale
Might throw in a few as a sweetner
Minicooper
| posted on 8/2/10 at 09:29 AM |
Chris
Chris,
Sorry about the delay checking the weight, yes it a lot heavier than 25kg, more like 45kgs
I need this stuff shifted especially the larger stuff, reasonable offers excepted
