Author: Subject: FS: ExtraEFI Megasquirt 1 V3 (NEW)
hobbsy
posted on 1/3/11 at 12:00 PM Reply With Quote
As discussed in this thread here:
http://www.locostbuilders.co.uk/viewthread.php?tid=150349
"MS1 chip, V3 PCB. Regular idle valve transistor has been upgraded to a high power transistor (2nd from right), standard mod from ExtraEFI. Spr1 is connected to something, but without seeing the underside of the PCB it is impossible to say. I presume this is the knock input from the external filter box. I can only see the one spark driver. Some second spark drivers are fitted to the underside of the board, but the one I have from ExtraEFI has the second FET installed in the space in the heatsink on the topside, not present on yours. Will work up to 8 cylinders with the correct EDIS module, or 2 cylinders wasted spark. Installing a second FET is pretty easy though for anyone handy with a soldering iron. All MSs have provision for 2 temp sensors (water and air). Can't see any others fitted (EGT sensors, etc.)."
I will post up a better version of the first photo later when back at home. It *does* come with a knock sensor and interface box (you can see this in the photo above, the white sheet describes how to connect it up).
It's never been used, change of plan (could also do with cash to fund new kitchen )
£245 plus post?
Larger photo of inside here:
hobbsy
posted on 3/4/11 at 04:27 PM Reply With Quote
Still available, open to serious offers else eBay beckons (as its a free listing day today)
hobbsy
posted on 3/4/11 at 05:34 PM Reply With Quote
Too much stuff to list on eBay so I've whacked it on anyway at £225 starting price:
Megasquirt MS1 V3 NEW with knock sensor etc ExtraEFI on eBay (end time 10-Apr-11 18:30:59 BST)
