steveiow
| posted on 17/3/12 at 08:07 PM |
750MC Locost Parts Clearout
Exhaust manifold and silencer
Was a spare and was previously fitted to last years race car (Locost Series) but now no longer required.
Comes with heat wrap (could do with re-wrapping if you are fussy) as well as repackable silencer.
£100 delivered.
Fresh Build Race Engine
This is my spare engine from last season and is a cracking engine, one test day old.
Engine was built by a local reputable engine builder with many years experience of building crossflows and cosworths as well as rebuilding and
maintaining a famous historic F1 car. Build quality and attention to detail is therefore spot on.
This engine was built as a plus 60 thou overbore and was then set up correctly by Tom Airey who is a specialist at setting up ford engines and in
particular carbed engines. Engine was then tested for an entire day at Brands in Feb 2011, then removed from the car and crated. My 2nd engine was
then built to exact same spec bar it being 90thou overbore and again sent to Tom Airey and set up and run in exactly the same way as the plus60 I am
selling. The plus 90 raced 13 rounds plus heats and the Birkett 6 hour with no issues other than a quick check of valve clearances mid season and a
new head gasket for the Birkett.
So, apologies for the history, but I think the reliability and performance of the plus 90 proves that this plus60 is a good strong engine.
With regards to power delivery, the plus60 thou gives around 300rpm more to play with at the top end over the plus90, something I found very useful at
Brands Hatch for example where you would over-rev a plus90 as you head towards Graham Hill Bend, whereas the plus60 still had more to give. Peak power
is slightly less than the plus 90 engine but the way it revs more than makes up for this - its a little screamer of an engine and in testing in Feb
2011 we ran cosistant sub 60 second laps around the indy circuit. I would have no issues with running this engine in the 2012 championship.
Engine is ready to drop in and use and complies fully with the 2012 regulations. Comes with everything fitted including brand new uprated clutch,
distributor running Aldon Ignitor electronic ignition, oil pump, carb etc. It really is a turn key engine - just need a starter, alternator, air
filter, dizzy cap and leads. I can supply all these too at extra cost (except for the air filter).
Runs on Millers CSS 20w50.
£1500, photos available on request.
Various springs, £25 a pair delivered:
2.25" by 7" 200lbs
1.9" by 7" 375lbs
1.9" by 8" poundage unknown
1.9" by 9" 100lbs
Brand new unfitted 3 bolt inertia starter suitable for crossflow, from Burtons £50 delivered. Same as Lucas LRS100
Lucas Sport Coil DLB105, brand new and unfitted £25 delivered
Facet Fuel Pump 476087 4-5.5psi, good working order with box and instructions £35 delivered
Starter Solenoid fits mk2 escort and anything with the inertia starter listed above (cortina,capri etc) £10 delivered
Dizzy cap, side entry, for Ford Bosch distributor. Brand new unfitted £8 delivered
Dizzy cap for Lucas distributor side entry. Brand new unfitted £8 delivered
Aldon Ignitor electronic ignition - whole kit for 43D4/45D4 Lucas distributor. 4 cylinder -ve earth, Brand new and unfitted, £60
Auto Gauge Oil Pressure Gauge. Complete with sender, boxed with instructions, never fitted. £10 delivered
Steering rack, refurbished, standard ford escort mk2, approx 3.3 turns lock to lock, £35 delivered.
Alternatively to posting/shipping, all items could be brought to Silverstone for Rounds 1&2.
u2u or tel 07717844767
I will be adding other items to this post shortly.
[Edited on 17/3/12 by steveiow]
[Edited on 18/3/12 by steveiow]
2012 Locost Race Car #12 - for everything Locost Racing: www.SEWC.co.uk
steveiow
| posted on 18/3/12 at 05:17 PM |
Bump as added lots of extra bits I just found in the garage.
Trollyjack
| posted on 18/3/12 at 09:08 PM |
I'll take the thermostat housing
sent you s U2U
TrollyJack
beardmore4072
| posted on 21/3/12 at 08:12 PM |
I will take the oil pressure gauge please.
jossey
| posted on 26/3/12 at 08:06 PM |
Rack please :-)
David Johnson
jonno
| posted on 26/3/12 at 08:26 PM |
Can you please U2U me the best price on the starter motor and solenoid including delivery ?
having fun on a budget
