nre
| posted on 24/1/13 at 02:07 PM |
Zetec with 16 bent valves - FREE TO COLLECT
My 1800 zetec suffered a cam tensioner failure last year, the engine is now sat around gathering dust. Head is off, all 16 valves are bent, pistons
have slight marks from valve contact.
Bottom end should be ok - was running well prior to the 'incident'!
It's a 1994 engine, 130ps spec.
If anyone wants head, block or both, drop me a message.
Collect from Warwick...
Sylva Mojo Zetec on GSXR750 throttle bodies...
www.mymojo.co.uk - Facebook feed
JPSC Forum - A dedicated forum for discussion on all things relating to Jeremy Phillips designed cars
Including the Star, Leader, Striker, Phoenix, Fury, Jester, Stylus, Mojo, Riot, J15 & Vectis
cliftyhanger
| posted on 24/1/13 at 06:06 PM |
don't suppose you have the top and lower cambelt covers do you? I am still looking (only got the middle one )
nre
| posted on 24/1/13 at 06:12 PM |
One of the bits of the cambelt cover has a hole through it courtesy of the exploding cambelt tensioner pulley, think it is the middle one, so should
have top and bottom ones available... I'll go have a dig through the parts bin!
cliftyhanger
| posted on 25/1/13 at 07:18 PM |
This may be a bit of luck for me!! At last
dave-69isit
| posted on 25/1/13 at 11:27 PM |
engine
hello is the engine stillavailable please can collect any time
nre
| posted on 26/1/13 at 08:53 AM |
Bottom half of engine just been picked up by madteg.
Still have the head.
cliftyhanger - if you u2u your email address I'll send you a pic of the bits I found - hopefully they are what you are after!
