skidmark
| posted on 16/3/14 at 04:16 PM |
pro race 1.2 wheels and tyres
I have a set of four 15" pro race 1.2 wheels in gloss black with toyo t1R tyres as supplied by MK for my indy. Was planning on using them for
trackdays but never got round to it. Only done a few road miles so basically all as new. Note that they need centre bore adaptors to fit sierra hubs
since MK didn't send any and I had to use the ones from my existing wheels which I still need. I'll add some pictures if need be later
although nothing to note really. I think MK now sell these for around £640 probably plus vat. Looking for 550 - collect or arrange courier from
norwich area. Thanks.
jrrsparky
| posted on 16/3/14 at 08:47 PM |
Hi, what is the offset/ET of these wheels.
skidmark
| posted on 16/3/14 at 10:33 PM |
I think the offset is 35mm but will have to check when i'm home tomorrow. Its whatever MK supply as standard anyway. Thanks.
skidmark
| posted on 18/3/14 at 08:44 PM |
I've had a look at the wheels finally but the offset doesn't seem to be marked on them. All I can see is 7J x 15 CH - not sure if CH is
an offset code? I'll try to measure / calculate if needed. Thanks.
theduck
| posted on 18/3/14 at 08:57 PM |
On the back of the wheel on the hub mating face there are 4 oblong ish have holes. The et should be engraved in one of them. The letters et are cast
into the wheel and the number should be engraved. They aren't always done though.
skidmark
| posted on 18/3/14 at 10:39 PM |
Ok thanks, must have missed that. Will have another look later.
CosKev3
| posted on 19/3/14 at 08:10 AM |
On 1.2's the ET is scribed onto the inner wheel rim where the tyre mounts, it's quite hard to spot if the paint is abit thick.
skidmark
| posted on 19/3/14 at 09:48 PM |
Ah yes, the offset was indeed on the inner rim but very difficult to see! I can confirm the offset is indeed 35mm. Thanks.
skidmark
| posted on 21/3/14 at 11:40 AM |
Any offers before they go on fleabay?
