3SGE RWD Conversion kit. T50 gearbox etc.
Firstly, happy New Year everyone! Following a successful six speed box conversion I have for sale almost everything you need (transmission wise) to
fit a Toyota 3SGE 2 litre 16V engine into your car in rear wheel drive format.
The 3SGE is found in Celicas and MR2s amongst others and is a cracking engine giving up to 178 bhp in standard form.
I first fitted a 3SGE in my Spyder Silverstone about ten years ago. It previously had a 2TG 1600 Twincam in it. The engine swap necessitated modifying
the bellhousing to accept the larger flywheel and re-drilling the mounting bolt and dowel holes. This was done by measuring the 3SGE pattern (using
the engine backplate) on a CMM machine and machining on a CNC milling machine. It also needed 5mm off the front face. (I was in aerospace at the
time). It fits perfectly.
The T50 box is a peach with a beautiful gearchange. Together with it are...
A suitable clutch plate to match the engine-box combo
Starter motor
Slave cylinder
Propshaft to suit Sierra diff
Gearbox mount for you to mod
The box is 730mm long. The box plus prop is 1280mm.
The box had a slight whine in 3rd when I got the car and it still has it. It has got no worse over the years.
I am using the REV3 engine. I see no reason why it should not fit an earlier type.
I will help the buyer as much as possible with other aspects of the 3SGE RWD conversion. Its worth the effort. Trust me.
I am 5 minutes from M1 J27. I can deliver within a reasonable distance or meet up.
£400 for the kit.
