Author: Subject: Fully pneumatic paddle shift for sale
daniel mason
posted on 20/5/15 at 04:00 PM Reply With Quote
I have a full pneumatic xoomspeed gearchange for sale! All brand new and unused.l
7 litre fill tank + whip and fittings
0.8l onboard fill tank with nice adjustable pressure reg sourced from the usa
Xoomshift solo gear control unit.
Steering mounted paddle shift kit with neutral lockout switch (hold this in when in 1st and it will make a half shift to neutral)
Dual action shift actuator with magnetic piston.
Magnetic sensors which neatly mount in the recesses in the actuator.these detect when the piston is at full travel in either direction before restoring power
Top quality valve block with voltage suppressor
Throttle blipper
All hoses and one touch fittings also included!
The. Only thin needed is a home made wiring harness as there is no off the shelf looms for these kits at the moment!
The kit is very high quality and has several brilliant features like fully automatic upshifts at set rpm's in set gears, it has the ability to not downshift at overly high rpm's which can also be set to suit the car.launch and traction control can be added,as can a digital gear indicator.
Obviously this is based more towards a competition car and runs a small onboard air tank. But you coul easily buy and fit a compressor for less than these tanks are worth if track days or road miles are what your into!
Am after £1k for the whole kit which is a big saving and David loomes from xoomspeed has offered his help to any potential buyers. He's a top bloke and very clued up on all things sequential! Cheers
jeffw
posted on 20/5/15 at 05:25 PM Reply With Quote
Excellent price
daniel mason
posted on 21/5/15 at 01:30 PM Reply With Quote
Thanks Jeff. It's a brilliant system for closed loop flat shifting.for less than an electronic setup
daniel mason
posted on 29/5/15 at 06:56 PM Reply With Quote
Bump for a fantastic clutch less flatshifter setup!
daniel mason
posted on 30/5/15 at 04:59 PM Reply With Quote
Now on the bay of-E
http://m.ebay.co.uk/itm/261908367507?nav=SEARCH
seward1980
posted on 31/5/15 at 02:46 PM Reply With Quote
I agree excellent price
daniel mason
posted on 31/5/15 at 03:50 PM Reply With Quote
It's only at £165 at moment so get bidding
jeffw
posted on 31/5/15 at 04:45 PM Reply With Quote
I'll make them pay mate....or get a bargain !
daniel mason
posted on 31/5/15 at 04:59 PM Reply With Quote
You going sequential JW? I'll hopefully see you at wscc blyton anyway for a natter! Do you know when regs and entry is out? As nick Algar is t doing it this year and not sure who is!
jeffw
posted on 31/5/15 at 06:26 PM Reply With Quote
All ready booked in and paid on that one Dan. I have a 6 speed sequential in the car so....
daniel mason
posted on 31/5/15 at 06:33 PM Reply With Quote
Where did you book on jeff I can't find any links on wscc site?
jeffw
posted on 31/5/15 at 06:44 PM Reply With Quote
http://forum.wscc.co.uk/forum/index.php/store/
This was what I was sent
daniel mason
posted on 31/5/15 at 07:48 PM Reply With Quote
Thanks jeff
