kingster996
| posted on 5/2/17 at 10:21 PM |
VDO instruments and rocker switches
As I'm moving to a full digital dash my old set up is now available.
VDO Vision range only used for 18 months
80mm Speedometer 140mph with 7481 miles on. Intermittent LCD display flicker (no idea if it's wiring or instrument) otherwise works fine hence
£30
80mm Tachometer 0-7000rpm £75
52mm gauges: 10bar oil pressure, fuel, 150 deg oil temp, 120 deg water temp. £20 each oil pressure has slight paint chip on bezel but easy touch
up
All 6 for £175 or will split if nobody wants a full set.
Also have rocker switches for lights, main beam, fog and brake test £20 for all 4, may split
All plus postage.
I used to be indecisive, but now I'm not so sure
kingster996
| posted on 6/2/17 at 04:45 PM |
Switches sold.
WesBrooks
| posted on 6/2/17 at 05:22 PM |
Is there a way to zero the ODO?
http://doctrucker.wordpress.com
kingster996
| posted on 6/2/17 at 08:48 PM |
Not sure but they're all sold now I'm afraid.
