Rallye_Mark
| posted on 16/11/10 at 09:52 PM |
FS: Sierra 240mm Solid Front Brake Set-Up & R1 Propshaft Adaptor
As the title says, a while ago when I was planning on running a motorbike engine in my car I was going to use the 240mm solid disc front set-up to
keep weight down, however now that I am using a heavier car engine I will be switching to vented discs.
The calipers are brand new and boxed (however one box is missing but the other one is still in its box)
The Front discs are brand new and boxed also.
Here are the picture I took when they arrived
Dunno what to ask for them but to get rid of them I'll take £60 delivered.
I will also be selling my R1 to Sierra Propshaft converter that includes a section of the Sierra Propshaft upto the rubber connector, think these are
quite expensive to buy new so will ask for £60 delivered aswell and take a slight loss on it.
Will try and get pictures this weekend of it.
Cheers Mark
sickbag
| posted on 17/11/10 at 08:34 AM |
I'd be interested in the prop adapter - can you tell me the version it's for.
Thanks,
T
Finally back on the job!
Rallye_Mark
| posted on 17/11/10 at 10:02 AM |
Thanks,
T
I'm not 100% sure but I think it's for roughly a '99 year, I can do some measurements at the weekend to confirm if anyone can tell
me the differences between the years?
Cheers Mark
sickbag
| posted on 17/11/10 at 10:33 AM |
I'll check as well but I thought they were the same from '99 to '03, then changed for 2004 onwards.
Rallye_Mark
| posted on 17/11/10 at 04:03 PM |
If i remeber correctly it is for that kind of age as I was planning on using an older motor, so probably a '99 to '03.
sickbag
| posted on 17/11/10 at 05:24 PM |
Just checked and they're the same from '98 to '03 so I'll take it and the prop' off your hands please. Can you U2U me
the details please.
Thanks,
Tony
Rallye_Mark
| posted on 17/11/10 at 06:38 PM |
U2U sent to "sickbag" regarding Propshaft Adaptor
Rallye_Mark
| posted on 21/11/10 at 09:09 PM |
Picture of the Propshaft Adaptor and the Part of the Sierra shaft that I've included.
Cheers Mark
Rallye_Mark
| posted on 10/12/10 at 01:33 PM |
Up to the top, no reply about last one interested.
I will be needing to remove the last part of the Sierra shaft from the rubber mount back for my own but the rest is still included, the section just
between the sprocket and the rubber bush also has splines of some kind as it can be lengthened or shortened as required.
Cheers Mark
