Author: Subject: Throttle Bodies, Engine Management (ignition), DCOE Carbs + more (garage clearance)
garybee
posted on 18/7/11 at 08:15 PM Reply With Quote
Yamaha R1 Throttle Bodies
Set of Yamaha R1 throttle bodies complete with injectors, throttle position sensor etc. There is a small mark on the inlet side of one of the bodies that has been blended out which will not affect them in use. These are separate bodies that can be easily respaced to match your engine. Pictures are in my gallery.
£110 plus postage at cost
Weber Alpha ignition ECU for silvertop Zetec (1.8 or 2L)
Weber Alpha Ignition ECU for a silvertop zetec. This is complete with loom and has a map already installed to get you running. This is the best way to get a mappable ignition system and would be ideal for someone running DCOEs (I also have a spare set of these lying around) or bike carb's.
Description copied from Burton Power:-
Product Description.A state of the art 2D electronic ignition system featuring an ignition map of 16 RPM sites that can be upgraded to full 3D ignition management by the addition of a throttle position sensor (16 RPM x 16 engine load sites). The system features an engine speed limiter, and there is also a tachometer output drive and a gearshift lamp drive. Engine specific systems are supplied calibrated for a standard specification engine. Each kit includes: ECU, wiring harness, inlet air temperature sensor and cable ties. . ECU, WIRING, AIR TEMP SENSOR & FITTING PARTS
http://www.burtonpower.com/parts-by-fitment-type/parts-by-engine-ford/ford-zetec-e/webk97017.html
The loom was fitted to the car but not the ECU, changed my mind.
Burton have this for sale for £458, I'm looking for £250 ono.
Weber 40 DCOE carb'
Single Weber 40 DCOE. This has been standing for a while and could do with a service and will need jetting to your engine of course
£60
Fuel Swirl Pot
Aluminium Fuel Swirl Pot (unused), 150mm x 130 x 130. Complete with AN to UNF fittings for high pressure hoses.
£30
Header Tank
Aluminium header tank 150mm tall x 80 deep x 160 wide. This has a standard cap fitting but no cap. Fitted but never used, would look new with a polish.
£30
Oil Catch Tank
Aluminium oil catch tank 190mm tall x 85 deep x 130 wide with sight tube. Fitted but never used, would look new with a polish.
£30
More to be added later
Pictures for all items should be in my gallery. If I've missed anything please just give me a nudge and I will upload one for that item.
[Edited on 19/7/11 by garybee]
snapper
posted on 19/7/11 at 05:27 AM Reply With Quote
First ribs on the header tank and a photo of said tank please
I eat to survive
I drink to forget
shindha
posted on 19/7/11 at 08:13 AM Reply With Quote
I am intrested in the catch tank and 2nd dibd on the header tank could you send some pictures please if you have already sent me a picture of the catch tank I might have deleted it - some one sent me a picture of a header or catch tank that I asked for may be on here or some other forum. Memmory is not my greatest asset ..
shindha
posted on 19/7/11 at 08:15 AM Reply With Quote
DOH !! Also meant to ask is the ECU suitable for running throttle body set up - couldn't find any information on their website or on Northampton Motorsports site.
garybee
posted on 19/7/11 at 11:25 AM Reply With Quote
I'm afraid I don't do dibs, whoever commits to buying something first has 'dibs' on any item. I always stick rigidly to this in the interests of fairness as some people will call 'dibs' on anything they might be interested in.
The engine management setup is ignition only, so can't run throttle bodies. It's intended for use by someone running carb's.
Pictures for all items should be in my gallery. Should have said this in the original post (now edited)...sorry.
snapper
posted on 20/7/11 at 06:09 AM Reply With Quote
Need a photo of header tank before I commit
Outlets size and position are important as is fixing method and position.
You don't do dibs.
I don't buy blind.
I eat to survive
I drink to forget
garybee
posted on 20/7/11 at 10:48 AM Reply With Quote
You don't do dibs.
I don't buy blind.
There are pictures of the items for sale in my gallery, nobody is asking you to buy blind. I will however be selling all items to whoever is the first to commit to paying for them. What I was trying to help everyone to understand is that nobody has 'dibs'.
If the descriptions in the OP and the pictures in my gallery aren't sufficient, please just ask and I will add more.
garybee
posted on 21/7/11 at 12:02 PM Reply With Quote
Swirl pot and header tank provisionally sold. Everything else still available.
garybee
posted on 15/8/11 at 08:13 PM Reply With Quote
bump...
ECU and carb' no longer available, all other items still for sale. Swirl pot and header tank still for sale too.
[Edited on 15/8/11 by garybee]
ChrisLeary
posted on 16/8/11 at 06:57 AM Reply With Quote
i'll have the header tank.
Cheers, chris.
obr_technology
posted on 16/8/11 at 07:44 PM Reply With Quote
Do you still have the swirl pot? If so could you send over a picture?
Olly
garybee
posted on 17/8/11 at 07:32 AM Reply With Quote
Originally posted by obr_technology
Olly
Hi Olly
Yes, still have the swirl pot. There is a picture of it in my photo archive, please let me know if you need another picture and I will add.
Gaz
garybee
posted on 25/8/11 at 12:01 PM Reply With Quote
Engine management and Carb's sold, all other items still available.
[Edited on 25/8/11 by garybee]
