Workshop Rolling Cabinets
Well not strictly workshop Cabinets but actually Laptop Trolleys. But they are very very sturdy well made items. They have both seen little use and as
such are in A1 condition.
Trolley 1
Measures 920mm Wide X 585mm Deep X 1080mm High.
The shelves are only located using 2 rivets each end so 2 minutes to drill out and remove as many as you want. Built in Power strips in the back so
perfect for storing power tool chargers? Only issue with his unit is that it has no key. it opens and closes fine with a screwdriver but
wouldn't cost a lot to get it re barrelled at your local Timpson's. Wheels are top quality industrial items so roll smoothly and 2 have
locks which work fine.
Make me an offer over £100, its probably worth £40 in scrap as its quit heavy. Collection form Market Drayton Shropshire or I can deliver to the
Birmingham / Dudley / Wolverhampton Area for £15 as I'm working in that area for the next 5 weeks and have a van. Alternatively I can wrap it in
industrial cling film for you to have collected at your cost.
Unit 2
A bit lighter and smaller than Unit 1 and to be honest probably makes a better workshop trolley as its lighter, has handles etc.
This unit measures 550mm Deep X 900mm Wide X 930mm High. It has power inside the cabinet and also has a handy 4 gang fixed to the top work surface.
The partitions again are just riveted in and the last pic shows one I have already removed the partitions from for my own use. Again top quality which
has seen very little use.
Both of these units have had the flex cut off as the seller wasn't allowed to sell them with working electrics. I have re flexed the one
I'm keeping though and it took about 15 minutes so not a big job.
If these were painted red they would be worth £400+ I'm sure :-)
At the moment I have 1 of each but more may be coming my way.
