ChrisW
| posted on 2/2/08 at 07:16 PM |
Megasquirt V3 with ALL options!
Megasquirt ECU, built on V3 (latest) hardware, in the proper cast black case.
Built by me - trained electronic engineer with 10 years experience of electronic design, build and diagnosis - and fully tested on the proper
stimulator.
This one has all the options fitted - low impedance injector drivers, coil/hall or VR timing options, PWM flyback for idle valve, current limiters so
you can't blow it up.... everything! All the major components are fitted, but there are six other small parts that you might need to fit if you
need a special setup - these are included too, or I can fit them for you if you know you need that configuration.
Currently set up with the jumper that allows EDIS ignition, although this is easily removed if you want to drive a distributor - again, if you tell
me, I can do this for you.
Running the standard firmware, so you have a known entity to start with. If you want EDIS, you need to change the firmware, but this is easy to do.
I've left it standard, as it can be a nightmare getting it to work if you don't have the exact same setup on your PC as you do on the ECU
- this way, it will work with the tuning software straight from the Megasquirt, and you can make your own decision about which version to run if you
do decide to change.
Box is brand new, only ever run on the stimulator (test rig) never in a car. Built it for running a Zetec in my XR2, but it seems silly to have
options fitted that I don't plan to ever use on this project, so if it sells I'll build a more basic one.
Also included brand new 37-way plug, ready to wire up to your loom.
This is perfect for running Zetecs, and other modern EFi engines, but as it has all the options fitted, you can run pretty much any engine from it and
get the reliability, fuel consumption and power benefits that EFI gives.
System is fully live mappable from laptop with no need to stop the engine - if your passenger is operating the laptop, you can even remap whilst
moving!
£225 posted!
Chris
scutter
| posted on 3/2/08 at 05:11 PM |
U2U on it's way, Chris
ATB Dan.
ChrisW
| posted on 10/3/08 at 06:44 PM |
Two more of these now in stock!
One is assembled (by me - see above), tested and ready to go out.
One is currently unassembled, will be ready in 2-3 days.
As above, £225 delivered with all the options fitted. Both are in the nice black cases.
Chris
RoadkillUK
| posted on 10/3/08 at 07:39 PM |
Oy, anymore of this selling and you'll have ChrisW on your case
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
