| posted on 23/3/09 at 05:33 PM |
Dymags and Goodyear Fiorano F1's - REDUCED!
First things first... the picture is a shocker and makes the wheels tyres look really scrappy. It's just grease, dust and my poor
photography!
Set of 4 Magnesium Dymag Wheels & Tyres. Specification and sizes are as follows:
Front 8J x 18
PCD 112mm x 5
Offset 32mm
Spigot diameter 63mm
Weight 8kg
Rear 10J x 18
PCD 112mm x 5
Offset 56mm
Weight 9 kg
These were used on a prototype car for less than 500 miles testing use. The stud pattern is same as Ford Granada/Scorpio, and also Mercedes, VW, Audi.
These wheel were over £2k when new! The tyres were another grand!
Tyres fitted:
Goodyear Eagle F1 (GS Fiorano) Fr 225/40 ZR 18 With 6mm Tread
Goodyear Eagle F1 (GS Fiorano) Rr 295/35 ZR 18 With 5mm Tread
VGC (one or two small chips or scuffs) and a bargain at £499 including UK delivery. Honest - this is almost a 'give-away' price!
Image deleted by owner
[Edited on 13/4/09 by scootz]
mcerd1
| posted on 23/3/09 at 06:51 PM |
(scott, if you don't mind I'll just add) - its quite easy to fit the granada hubs into sierra uprights
the rears are a strait swap with the bolt-on driveshaft type sierra ones
and the fronts just need turned down a little in the lathe to fit the sierra bearings and seals - like this:
so don't think these won't fit just because you've got sierra hubs
| posted on 13/4/09 at 09:59 PM |
Cheers Robert!
They're an absolute bargain for someone and price has been reduced even more!
Sure, they're a bit of a bizarre offset (that's the only reason the price is so low), but you can accommodate it if you're building
your own car!
