:{THC}:YosamiteSam
| posted on 11/4/09 at 09:34 AM |
stainless exhaust system
this will fit any seven type car as the manifold rises over the top rail - exits thro the engine cover
the side can can be cut down to suit
the end cap on the can is removeable for repacking
the rear brackets are mounted to the floor panel using the supplied bracket included - will fit any seven and sounds - well if you have heard a dax..
stainless exhaust systemstainless exhaust system
big_wasa
| posted on 11/4/09 at 09:40 AM |
Thats a good locost price if its in good nic and not bent.
dunk3
| posted on 11/4/09 at 09:47 AM |
Hi would this fit a 2.0L blacktop
:{THC}:YosamiteSam
| posted on 11/4/09 at 09:48 AM |
the only damage is the rear mounting bracket - which is part of the end cap welded to the end cap - the cap is removable - the bracket can then be put
in a vice and bent straight - it would be wrong for me to not say it wasnt bent but by leaving as is - it keeps the price down and its not a hidden
bit of damage - easy ten min fix.. if you have a vice..
once assembled and sealed together the system never has to be dismantled - because it goes over the top rail you can undo the manifold and the rear
bracket - lift the lot off in one peice so you dont break the joint seal.. clever.. - lots of cars go thro the side panel wall which means you have to
dismantle fully...
:{THC}:YosamiteSam
| posted on 11/4/09 at 09:50 AM |
i dont know - if someone can advise the fitting sizes - it was for a 1.8 silvertop.. exhaust exits left hand side - what side is the black top?
speedyxjs
It wont fit mine. Mine exits on the other side and has two more cylinders
:{THC}:YosamiteSam
| posted on 11/4/09 at 09:54 AM |
slap - wet fish
dunk3
| posted on 11/4/09 at 10:19 AM |
the blacktop exhaust exits the same side as a silver top, but are the manifolds the same.
big_wasa
| posted on 11/4/09 at 11:10 AM |
Yep easy fix.
It will bolt direct to a black top. Port shapes are a little differant.
ben salt
| posted on 11/4/09 at 12:03 PM |
you've got mail....
:{THC}:YosamiteSam
| posted on 11/4/09 at 02:08 PM |
first dibs ben salt
2nd dibs simon (smac)
subject to postage and payment of course..
MakeEverything
| posted on 11/4/09 at 05:33 PM |
Mines got two extra and exits on both sides!!
Kindest Regards,
Richard.
