:{THC}:YosamiteSam
| posted on 11/4/09 at 09:44 AM |
raceline zetec sump
i have a raceline ally sump for sale to suit zetec silvertop 1.8
will give ground clearance upto the level of type 9 bellhousing - which in fact i think is slightly lower than the sump..
is baffled.. has internal filter
has internal oil pick up
to fit buy new standard OEM 1.8 sump gasket
remove old oil pick up pipe - fit gasket - fit sump!
i'm selling this for just £150 + pnp.. bargain and a good upgrade
some info from raceline
Technical Description
The Raceline Performance Engineered cast alloy sump pan is designed to allow the greatest possible ground clearance when installed in a Caterham Seven
or similar type vehicle. In order to accomplish this whilst at the same time ensuring adequate oil capacity, the sump must necessarily be wide and
shallow, when ideally perhaps, a sump should be tall and narrow. This is an unavoidable compromise, which could result in oil surge, but for the
advanced design of the Raceline sump pan with its extensive baffling and built-in windage tray, meaning that oil surge is practically eliminated.
However, it does mean that the oil level in the sump is critical.
The sump holds a full five litres, and we recommend that owners recalibrate the oil dipstick to suit their particular vehicle installation. Once the
engine has been installed in the car, fill the sump with precisely five litres of your chosen lubricant (measuring carefully to ensure accuracy), then
lightly scribe a ‘full’ mark on the dipstick. For obvious reasons you should ensure that the vehicle is situated on a flat and level surface. If
practicable, it is highly desirable that the vehicle is positioned in the same place every time the oil level is monitored thereafter. You should aim
to maintain the oil level at the maximum mark at all times, checking as frequently as proves necessary to ensure this. Raceline has found that the
Ford Zetec engine is exceptionally oil tight, and seldom if ever needs topping up between oil changes in normal service. However, any engine will use
some oil if subjected to exceptionally hard use - on a race circuit at track days for example - especially when oil temperatures are high. Therefore
frequent checks are a must…
The Raceline cast alloy sump pan is designed for use with the standard Ford windage tray as supplied with the engine, which should therefore be
retained in situ. However, in order to fit the Raceline cast alloy sump pan, the mounting studs for the Ford windage tray, which form an extension to
the No2 and No4 main bearing cap retaining bolts, must be shortened slightly for clearance. Full fitting instructions are supplied with each kit.
Later engines from Ford have a cast alloy sump with integral cast-in windage tray, with pressed steel pan, and in order to fit the Raceline
Performance Engineered cast alloy sump, some additional parts (available as a kit from Raceline – please specify when ordering) are required.
Provided oil levels are maintained at a satisfactory level, the Raceline Performance Engineered wet sump has proven to be totally reliable, even in
hard circuit use.
Although many hundreds are now in service all over the world, some may still prefer the greater confidence that dry sump lubrication gives. Various
options are available from Raceline. The ‘road’ type of dry sump pan should be used where the engine is mounted using the bosses cast into the block
in the conventional manner. Alternatively, a ‘race’ dry sump pan may be specified, which is reinforced to allow mounting of the engine from the sump
casting, at front or rear or both. Both types allow up to three scavenge ports, with pressure supplied by remote pump, or by the engine’s original
equipment internal oil pump. Additionally, pump mounting brackets are available to allow mounting in various positions.
Technical Documents
Wet Sump Pan Kit £375.00
Sump Gasket £18.00
Sump Bolt £1.00
All prices are exclusive of VAT
tcc21racing
| posted on 11/4/09 at 10:12 AM |
can i get first refusal on the sump pm sent, thanks tom
big_wasa
| posted on 11/4/09 at 11:05 AM |
Go on then what other zetec goodies have you got ?
:{THC}:YosamiteSam
| posted on 11/4/09 at 11:28 AM |
sold to tom subject to payment - good choice sir..
:{THC}:YosamiteSam
| posted on 11/4/09 at 11:29 AM |
none zetec left - i'm going thro the garage now see what i have left - there are lots of stuff i need to sort out!
Danozeman
| posted on 11/4/09 at 11:51 AM |
Bugger. Iv just paid more than that for a scholar one. The raceline is much nicer!!
Dan
:{THC}:YosamiteSam
| posted on 11/4/09 at 02:26 PM |
bugger again - i tried to sell it few months back to someone who said they wanted it then just didnt pay!!!! dont you just hate that?
so put it up again - sorry
