Author: Subject: Cortina fit drilled & grooved discs
stuart_g
posted on 5/6/09 at 08:40 AM Reply With Quote
I have a pair of solid 9mm thick drilled and grooved cortina fit discs as supplied by MNR for their R16 caliper setup. These discs are standard cortina fit so they will fit any M16 setup.
They are in excellent condition, no wear as they were only used for a few hundred miles, they have some slight rust colouring on them but this is only in the area's were the pad does not cover and it will rub off.
Pic's can be provided if needed.
£50 + post. (Not sure how much post will be due to weight).
These discs are £110/pr from MNR.
Contact number: 07891 588289
[Edited on 5/6/09 by stuart_g]
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 5/6/09 at 11:41 AM Reply With Quote
u2u'd
chris_harris_
posted on 5/6/09 at 01:10 PM Reply With Quote
let me know if the sale falls through, second dibs please.
Regards Chris
