Author: Subject: pinto parts first
rabbit
posted on 27/12/09 at 08:45 AM Reply With Quote
pinto parts first
pinto 2lt twin 45 webbers/rs 2000 alloy sump/eng mounts 205 block. comp/exhaust system. ali cam cover . eng turns over by hand no wiring £350 needs to be collected once sold and removed no storage space.
later vdo gauges speedo/rev/water/oil/fuel new /gearbox meant to have had work /hood & doors/ switches new/ loom all from early se westfield not used on the road maybe other parts based east sussex 07743982682
gavin174
posted on 27/12/09 at 10:17 AM Reply With Quote
hi very interested in engine...
where about in east sussex are you..
will give you a call
thanks gavin
[Edited on 27/12/09 by gavin174]
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 27/12/09 at 10:19 AM Reply With Quote
Terry's in Eastbourne Gavin
gavin174
posted on 27/12/09 at 10:50 AM Reply With Quote
engine provisionally sold..
cheers
rabbit
posted on 27/12/09 at 07:33 PM Reply With Quote
pinto
hi gavin yes you have first choice on engine . engine taken out oil like new still in engine also lighten flywheel by the looks of it see you tuesday
rabbit
posted on 29/12/09 at 06:12 PM Reply With Quote
thanks gavin for prompt collection
gavin174
posted on 29/12/09 at 06:42 PM Reply With Quote
Pleasure to meet you Terry..
thanks for the hand loading it..
(not sure about the councils sunshine coast bit thou!!!!)
