Author: Subject: For Sale - Discovery TD5 Commercial
posted on 2/2/10 at 11:33 PM Reply With Quote
Family member has a Land Rover Discovery TD5 Commercial for sale.
02 Plate
98k Miles
6 Months Tax
10 Months Test
3 Owners
5-Door Conversion (From New) By Land Rover Special Vehicles.
Blacked Out Windows from B-Pillar Back.
Rear Air-Suspension Replaced with 110 Heavy Duty Springs.
Tow-bar fitted.
Nice enough vehicle... only mechanical issue I can think of is that the ABS sensor-ring is corroded and needs replaced.
Pics tomorrow.
£4250 + VAT.
It's Evolution Baby!
locoboy
posted on 3/2/10 at 12:24 AM Reply With Quote
When you say the abs ring needs replacing, ..............
Is it showing an ABS fault on the dash or on the OBD?
Locoboy
posted on 3/2/10 at 12:31 AM Reply With Quote
Showing a fault on the dash... TC + ABS lights on.
locoboy
posted on 3/2/10 at 07:36 PM Reply With Quote
Its probably the ABS modulator shuttle valve these pack up with annoying monotony.
If it aint that then its more likely going to be just a wheel bearing, Once the bearing has some play in it then it throws out the air gap between the ABS sensor and the ring thus throwing up an ABS fault.
Neither are major expenses, Modulator block is about £100 (secondhand)plus fitting, Wheelbearing, you cant buy it on its own you need to buy the hob with the bearing in it approx £60 second hand + fitting
Good luck with the sale, the used prices have recovered considerably in the last 6-9 months.
Locoboy
posted on 3/2/10 at 08:25 PM Reply With Quote
Cheers for that.
I've had a look at commercials and the asking price is pretty keen by comparison.
locoboy
posted on 3/2/10 at 10:42 PM Reply With Quote
Yeah its a good price for a good workhorse.
Locoboy
