Author: Subject: Cheap Car Transporter/Trailer FOR SALE
Dangle_kt
posted on 5/2/10 at 11:01 PM Reply With Quote
My kit is registered now, and I'm confident I can drive more than 5 miles without it falling apart so it is time to sell on my trailer.
The spec is as follows:
Small trailer will fit locost on fine (bumps over trailer wheels -but winch makes light work of it), will also fit other kits, minis etc.
Based on caravan chassis but well built
Fully working brakes, serviced just before I bought it and still in good mechanical condition
tows well
it has an solid base, so no road crap covering the underside of your kit car
Winch fitted - works great
Complete with Ramps
Nearly new tyres
New spare wheel
Caged rear lights to stop them getting smashed.
Due to the inboard wheels it fits in a single garage - JUST.
Has fully working jockey wheel/handbrake/brake away saver cable
Has spot light fitted - but this is not wired up
It is not stamped with a gross capcity, which is good for those with a newer licence like mine, so you can either fit a plate off ebay, or leave it and get taken to a weigh station to prove you are legal.
I have used it about 20 times, with zero problems
Only bad bit is the indicators have stopped working (rest of lights work fine) however I think this might just be a loose wire, but havn't had time to play.
Selling for £385 in Liverpool.
If it doesn't go to a locoster I will ebay it, and probably make more - but I'd rather it went to a fellow locoster.
I will get pictures and measurements up over the weekend.
[Edited on 5/2/10 by Dangle_kt]
DavidW
posted on 10/2/10 at 06:24 PM Reply With Quote
Any photos?
