Author: Subject: Clearout lots of stuff to go....
flak monkey
posted on 9/7/10 at 09:40 PM Reply With Quote
ZX9R clocks, with kph speedo £15 posted
Image deleted by owner
Bosch recirculation valve - fitted to nearly all GM and VAG turbo cars. £7 posted
1.75" stainless 45deg bends. Brand new, normally £10 each. I have 4 available. £25 post for all 4.
Set of EV6 (duratec) injector connectors, plenty of length on the wire £10 posted
Ford KA/Fiesta steering coupling. Hex one end and splines which fit the escort rack the other. Ideal for welded shaft. Brand new ford part. £10 posted
Ford knock sensor, new £10 posted
1.9, 350lb 8.5" long springs. Not new so show some signed of use. Would clean up ok. £15 posted
260x10mm brake discs. One has a small groove in the back face, but wouldnt cause any problems. Ford stud pattern (4x108). Ideal for a custom brake fitment. Would go under 15" rims with powerlites a treat! Not new, but no measurable wear. £20 posted
Lots of random lengths of silicone hose, 32mm and 50mm mainly. Some bends as well. All in black. If you need a short length/joiner then I'll see what I have.
8x M12x1.25 wheel nuts. £10 posted
HTC Touch Diamond phone (O2 XDa). VGC, owned by me for 12 months before my upgrade. Still have the original box, instructions etc etc. Currently on O2 but can easily be unlocked. Will come with a full (but old) version of Tom Tom mobile installed
One of these:
http://www.htc.com/uk/product/touchdiamond/overview.html
£70 posted
3.92 open diff for push in shafts. A little dusty, but was cleaned and painted with new seals fitted before fitting it to my car 3 yrs ago. £50 collection only
Sierra rear drum brakes. No hubs, just the back plates, shoes, cylinder and drums. Shoes and cylinders were brand new, and show little to no wear. Cleaned and painted when fitted, but the backplates could do with a new coat of paint. £40 collection only.
Sachs clutch plate, 220mm ford. Ford the FWD gearboxes (smaller splines). Brand new. £10 posted.
2 new bottles of Castrol diff oil. Suits sierra diff, normally £8/bottle. Proper synthetic, GL5 spec. No use to me now I have fitted a plate LSD. £10 collected.
Lots of short lengths of -6 fuel rail. Mainly offcuts, but normally around 200mm long. So would suit twin cyl bikes or similar....
Sure theres more, but will have a look tomorrow!
[Edited on 9/7/10 by flak monkey]
Sera
http://www.motosera.com
owelly
posted on 9/7/10 at 10:18 PM Reply With Quote
Silicon O's.
I need six straight bits of silicon hose 100mm long. They are to join the 6 inlet runners to the inlet plenum. The problem is that the runners are 40mm o/d with a bead dia of 43mm and the plenum stubs are 45mm. Will 40mm dia stretch over the 45mm or will the 45mm dia squeeze down onto the 40mm/43mm. If you have anthing of the aforementioned, even if you don't have six bits, I could try them to see what I need.
Did that make any sense??
http://www.ppcmag.co.uk
speedyxjs
posted on 10/7/10 at 08:05 AM Reply With Quote
Dibs on springs please!!!
u2u sent
flak monkey
posted on 10/7/10 at 12:40 PM Reply With Quote
Knock sensor, diff, brakes and springs sold....
Sera
flak monkey
posted on 12/7/10 at 11:21 AM Reply With Quote
Bump
Stainless bends, recirc valve, injector connectors, steering coupling, discs still available.
Sera
welderman
posted on 12/7/10 at 12:04 PM Reply With Quote
will try steering coupling mate
Joe
adrianreeve
posted on 12/7/10 at 07:12 PM Reply With Quote
Flak
If the markings on the 45 deg bends are true, they are 1.5", not 1.75". Nearly grabbed them for my inlet manilfold, then looked again. Just didn't want someone else make the mistake I nearly did!
Adrian
flak monkey
posted on 12/7/10 at 08:00 PM Reply With Quote
Oops! My mistake, sorry
Sera
