GlynC
| posted on 18/7/10 at 05:43 PM |
Virtually Complete Megasquirt FI Kit for Pinto
DIY Fuel Injection System
Due to the recent sale of my beloved Westfield I have a nearly complete kit to convert a Ford Pinto (although could be used for other cars) to fuel
injection and electronic ignition.
The System is controlled by the MEGASQUIRT ECU and uses the Ford EDIS module which is included.
To assist there are many resources on the web and I have also printed some of the install manuals which are included in the sale.
Here we go the sale includes
MEGASQUIRT ECU V2.2 (professionally built by Bill Shurvington)
MEGASQUIRT Relay board to assist with the wiring (Again built by Bill Shurvington) Needs to be assembled to suit the application.
GSXR 750 Throttle Bodies adapted to fit the custom Pinto Manifold, but can easily be re-spaced. Second Butterflys removed and all holes filled with
metal and resurfaced. This includes injectors and Throttle position sensor.
Custom manufactured Aluminium inlet manifold to fit the Pinto with the water take off pipe. With the lengths of Samco Hose to link the throttle
bodies (beautiful job see photo)
Chrome finish Motorbike filters for the bodies.
EDIS Module (two of these supplied)
36-1 trigger wheel (which is attached to the crank pulley) and sensor
Inertia switch for the fuel pump
MEGASQURT Loom. Connector plug wired will obviously need connecting into the various parts of the circuit from then on.
Air temp sensor
Coolant sensor
Exhaust gas sensor
Injector wiring ( Will need trimming to fit application as you install)
Zetec Coil Pack
HT Leads for the above
Fuel pump with built in swirl pot
I want £500 for the lot: Which is a fair bit less than this lot cost. Never been used as I sold the car and the chap buying didnt want to get
involved in modding the Westy. This will take a fair amount of work and patience but is virtually complete and only requires a fuel rail and monir
parts to make it work (oh and a bit of know how!!). I never had the time to do it or use the car hence why she was sold
Based near Ashby De La Zouch (De11) or can post at cost. I reckon it wouldnt be over £15 to post in the UK . Will accept paypal Cash or Cheque
(although nothing gets posted or handed over until its cleared) email glyn-clarke@o2.co.uk . Can take more pictures if required. Might Ebay it if
it's not moved by Friday this week
So first dabs on this forum
David_17
| posted on 18/7/10 at 08:43 PM |
Would you be interested in splitting?
I don't need any of the pinto bits, manifold, trigger wheel etc.
Hugh_
| posted on 19/7/10 at 12:07 PM |
I might be interested, getting fed up with setting up carbs!
Do you know if 750 TBs are large enough for a 2.1 pinto with BV head, race cam etc.
Hugh
GlynC
| posted on 19/7/10 at 03:28 PM |
Hi
I'll answer both questions in one post if that ok
I would prefer not to split as I think it is a good package. If it doesn't go I'll come back to you though
Should be fine for a 2.1 thats what mine was. I had a Newman stage 4 cam and a big valve head on mine. I reckon they will make a lovely noise!!
GlynC
| posted on 26/7/10 at 10:11 AM |
Now listed on EBay
item number
160460136017
GlynC
| posted on 5/8/10 at 10:20 PM |
Dont you love love Ebay
After a week some t*sser decides he cant afford the kit now
So before I stick it back on there and incurr more time wasted does anyone want to make me a reasonable offer.
Just for info the manifold alone is £150
you know how much the ECU etc are all brand new only the bodies and the sensors coil etc are " recycled"
Would make a cracking project on a decent Pinto engined motor!
