hiflow
| posted on 6/8/10 at 09:21 PM |
BEC 893cc blade kit complete
Urban tiger , Fireblade 893cc N spec 1993.
Although I don’t have any record of previous mileage the sump was removed and bottom end checked prior to fitting. All was in good order.
A compression check was done on the engine last week and all 4 cylinders have a healthy compression of 147psi. The engine has only ever been run on
10-40w Redline Racing oil.
Oil pressure is over 100psi when cold & 85psi when hot. The carbs were recently rejetted by MB services, Fireblade Tuning specialist. The fuel
system + carbs have been treated with Redline fuel cleaner and the cooling system has only been run on Redline watter wetter. The engine has been run
with an oil cooler (but this is not included). Recently had new plugs & HT lead set.
Comes with pipercross 5000 seriers filter, ESt bhp 135bhp
The engine runs spot on, recently fitted 3.92 diff (was running 3.14) really suit this engine. Can supply max speed per gear table
Engine comes with CDi/Relays/Fuel pump/engine loom/fan relay/push button start switch. The bike loom has been extended and all light circuit are
included. Therefore the loom can be wired into your head/side/reverse lights & indictors/coolant fan. I,ve put multiplugs on the loom so light can
be plugged into the loom
4-2-1 branch manifold is included. MK item
I will mark up the loom clearly identifying revcounter/lights.
3.92 diff + shafts + drum brakes setup with new shoes + drums.
Engine can be heard running & tested.
Ideal for new build.
Got the chance of larger engine, hence only reason for sale.
[Edited on 6/8/10 by hiflow]
[Edited on 7/8/10 by hiflow]
ReMan
| posted on 6/8/10 at 09:42 PM |
£200?
hiflow
| posted on 6/8/10 at 10:05 PM |
only really wanted £50.
pekwah1
| posted on 6/8/10 at 10:37 PM |
so if this is for 'sale', how much?
D Beddows
| posted on 6/8/10 at 11:11 PM |
Ok £50 it is! u2u me the the address for the courier?....... you appear to have advertised it for that so I'll take
everything.......seriously!......
[Edited on 6/8/10 by D Beddows]
LBMEFM
| posted on 7/8/10 at 08:38 AM |
    Enough, enough, what is the real price?
LBMEFM
hiflow
| posted on 7/8/10 at 08:45 AM |
LOL sure thing i,ll also throw in my best shirt, that i have just removed for my back as well to close the deal.
Enjoying the crack, but i want to sell this.
Again Honda Fireblade 893cc for sale. The 'Urban tiger' were the very early Unrestricted blade with an on-off power band. When these came
out, people were buying them and then returning them back to the dealers due to Ferocious power delivery. Ideal setup for KC. Looking for £1500.00.
Can delivery to Manland UK for £55.00
Update. My engine number is SC28E-*****
the remaining engine serial numbers do not tally up with the numbers in Haynes manual, thus the engine is a Jap import. I contacted Honda UK on
Friday & they are going to send me written conformation of year of manufacture. So for IVA you will not need to fit a CAT.
Drop me mail if your intrested hiflowheads.sales@googlemail.com
