SEH engine block and other bits for sale.
2.0 SEH 8v Vauxhall engine Bottom end/block/short engine.
I purchased this engine for the head as the engine had been fully rebuild including uprated head.I was told that it had done arond 1000 miles since
the rebuild but that it had developed a knocking from the bottom end which the previous owner who did the work and was a mechanic suspected was the
big end bearings although I have not heard it myself.
Total mileage for this engine is unknown but as said it is believed to have been rebuilt around 1000 miles ago and I have no reason not to believe it
was after looking at the head and cam.
Other than the knocking that I was told had developed, the bottom end is in good condition and looks to of had new water pump and oil pump.
Looking at the bores there seems to be very little wear and no lip.The hone marks can still be seen down the bores.bare engine bottom end NO ecu or
wiring loom are included or head and associated parts.Complete 2.0SEH Block which also includes sump,oil pump,water pump,kent timing belt as well as
flywheel,alternator bracket.
ONLY £45.
Also Ford Granada front brake calipiers only one carrier as removed from car in scapyard.Any offers as having a clear out.
And a ford sierra r/h side stalk with wipers and lights looks to be in good condition but not used so unsure on condition.Open to offers.
Thanks Matty
