Author: Subject: Clearout....all good stuff
grassracer
posted on 31/8/10 at 07:38 PM Reply With Quote
Having a project garage clearout and found the following which may be of use to someone, all can be posted at cost
1600 cvh engine big valve head, race cam, vernier, dizzy, coil, Carl Schmidt pistons,very quick, very good can be heard/seen running if you're quick. £320 ono minus sump and oil pump!!
Dry sump kit to suit CVH engine, external pump, belt drive and pulleys, sump pan, large alloy tank and pipes all included £200 ono
Pair 45 Webers on long CVH inlet manifold inc Pipercross filter and throttle linkage,return springs etc carbs are great, filter ok. Manifold will need altered for a 7 type car. Will of course fit other engines if you change manifold £260 ono
Facet Red Top fuel pump and unions, used but good £40
Dial type fuel regulator good £15
Armtech Rev limiter adjustable inc wires £40
CVH starter motor used but good £15
Bullet type exhaust silencer painted black good used condition ideal Locost £30
This lot is for sale seperately but would consider a sensible offer for the lot, easily posted at cost or for collection....its still in the car and can be seen running if you're quick
[Edited on 1/9/10 by grassracer]
adrianreeve
posted on 31/8/10 at 07:44 PM Reply With Quote
I don't suppose you happen to know the type of starter fitted? I'm in need of an LRS543, which has a longer throw than the LRS707 one. If so, first dibs please!
Adrian
grassracer
posted on 31/8/10 at 07:57 PM Reply With Quote
Standard fwd starter I reckon
MakeEverything
posted on 31/8/10 at 08:34 PM Reply With Quote
U2U RE: Pump and Regulator.
Kindest Regards,
Richard.
DRC INDY 7
posted on 31/8/10 at 10:24 PM Reply With Quote
u2u rev limiter
Puddle Dodgers Club
