Author: Subject: shortened sump
David_17
posted on 8/9/10 at 08:08 PM Reply With Quote
shortened sump
I've shortened my 2 part blacktop sump but there's one bit that weeps, no matter how much i grind it back and weld, it always gets a damp patch when i fill it with water.
Anyone got one that doesnt leak spare??
Zetec or CVH should fit. Needs to be around 6" top to bottom.
Dave
posted on 8/9/10 at 08:52 PM Reply With Quote
Araldite or JBweld it where it leaks.
RichardK
posted on 8/9/10 at 08:55 PM Reply With Quote
Keep going mate, you'll crack it eventually!
Dont let a bit of metal get the better of you!!
Rich
Gallery updated 11/01/2011
RichardK
posted on 8/9/10 at 08:59 PM Reply With Quote
Put a tippex arrow of where it is, obviously far enough away not to be ground off, Grind it back and then get a butane or propane torch on the arrowed area and get it nice and hot, then try and weld it again, could be the cold start of the weld being porus which wouldnt be helping maybe.
Just a thought
Rich
David_17
posted on 8/9/10 at 09:22 PM Reply With Quote
Someone else suggested gasket paste. Have you had any look with either you mentioned
ashg
posted on 9/9/10 at 07:15 AM Reply With Quote
is it steel or ali? im guessing ali being a zetec. did you accidentally dip the tungsten around the problematic area?
if it was me i would cut out the dodgy bit and weld in a patch.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 9/9/10 at 08:31 AM Reply With Quote
I've used them on various problems and sorted them, fixed a header tank and bike crank case successfully
