flak monkey
| posted on 19/1/11 at 12:05 PM |
Clear out
Various sizes of Duratec cam followers. All virtually zero miles so no wear.
182 x1
142 x3
262 x3
302 x2
282 x2
New ones are £10 each from Cosworth. So £5 each.
Large official LCB sticker. New and still in the tube. £5
Sierra Haynes Manual - well used but all intact £5
Sticky backed reflectors £5
Phormula Knock Sensor interface cable £10
NGK BR7EFS spark plugs. Brand new, 1 step colder than standard for Duratec £10 set
Mk1 MR2 headlight retractor relay
Side repeaters - stick on with mini timer connection £10
T9 plastic gear lever saddle £5
New Duratec crank position sensor and alignment tool £25
VAG recirculating valve £7
Oil filter and EGR gaskets for duratec £5
Std pinto alternator pulley, key, nut etc (in bag) £7.50
Pinto manifold water outlet connector £5
M14 track rod end lock nuts (escort and sierra rack) £4 pair
Brake light test switch £5
Change over switch £4
On-Off-On switch £4
New Cortina hub dust caps (no longer avail from Ford) £10 pair
Type 9 to pinto support bracket £7.50
Prices inc post
Sera
http://www.motosera.com
Daddylonglegs
| posted on 19/1/11 at 12:13 PM |
brake light sw please
u2u sent
big_wasa
| posted on 19/1/11 at 12:43 PM |
Tina dust caps please.
will u2 you latter
Trollyjack
| posted on 19/1/11 at 08:08 PM |
Just U2U you
TrollyJack
flak monkey
| posted on 30/1/11 at 10:07 PM |
Bump
'tina caps and brake test switch sold, everything else available
Needs to go
Sera
