Author: Subject: FS..MILLING CUTTERS
SPYDER
posted on 9/2/11 at 09:41 PM Reply With Quote
FS..MILLING CUTTERS
Hi everyone! Here we have TWO used milling cutters.
Larger one is a SECO 250 mm 18 cartridge slot/face mill.
I can't read the numbers on it but I believe it to be from the 335-18 series.
All the cartridges look good as new.
Tips are part worn 12mm diameter. It is set up at the moment with all the tips level and has been used as a face mill on Titanium parts destined for the Joint Strike Fighter!
Central bore is 50mm. Drive slots are 12.2mm wide.
It can be set up with every other tooth staggered so can produce a slot wider than 12mm in one pass.
I have two packs of tips that are not exactly the same as what are in it, but they look OK to use.
They are SANDVIK R300 1240E PM
Smaller one is an ISCAR SGSF 200-4-40K.
200mm diameter wheel for slitting type operation. It takes push in type tips, similar to parting off tools.
Tips are 4mm wide and are part worn.
Central bore is 40mm. It has four 11mm holes on a 63 PCD.
All yours for £120 plus £10 post.
[img]http://[/img]
[img]http://[/img]
[img]http://[/img]
[img]http://[/img]
