hootsno1
| posted on 18/2/11 at 07:08 PM |
Eagle SS Cortina Based 2.0l Pinto
Hi All, I am selling this on behalf of my brother.
its an unfinished project and will try to list all the new parts fitted and other parts I have, the chassis and all major running gear Axel/sub
frame/wishbones and trailing arms have all been shot blasted zinc phosphate undercoated and then painted in exterior black floor sealer and fitted
back to the chassis using new full front and rear ploy bushes(will never need changing), new parts fitted are as follows upper and lower ball joints,
tie rod ends disc's pads and shoes rear brake slave cylinders all wheel studs and nuts all bearings(using high speed lithium grease) a re-con
2ltr pinto with all new gaskets and oil seals dizzy cap rotor arm leads and plugs, I also have a full set(never fitted so my be a piece missing)of
pre-bent steel brake lines and a reel of copper brake pipe if needed(will also include pipe bending tool if wanted)4 speed gear box(not fitted)
pantograph wiper and motor(fitted) two slim bucket seats(not fitted) steering rack(fitted) steering column(fitted) and pedal box(fitted)
body(unpainted) is on chassis but not secured plus any other bits I find for it, the car will need to be trailered away, reason for selling is due to
other commitments I no longer have the time to work on it, am looking to recoup some of the money I have spent on it so would be looking for offers of
£350.
Please look in my photos for pics
Cheers Mark
marcjagman
| posted on 18/2/11 at 09:27 PM |
Is the windscreen okay?
hootsno1
| posted on 18/2/11 at 09:53 PM |
sorry no the screen is cracked it is still bonded to the shell
