Toyota V6 aluminium flywheel
By a strange twist of fate I now have two of these and clearly only need one. Not sure if anyone is using the Toyota engine but worth an ask....
Fidanza aluminium flywheel for Toyota V6 engines:
1988-01 Toyota Camry 3.3L
1999-02 Toyota Solara 3.3L
1990-91 Lexus ES 250 2.5L
1992-93 Lexus ES 300 3.0L
They also fit the 3.0 '3VZ-FE' engine popular in V6 MR2 transplants, so the friction surface is compatible with the 'turbo'
clutch from the MR2.
These are only available from the States at around £225 depending on the dollar vs pound rate, plus you'll usually get stung at customs on the
way in.
Looking to cut my losses, so brand new in box never even seen the car.... £195 or a very close offer.
Cheers, Chris
