Author: Subject: CVH Engine, CVH Inlet Manifold
Norfolkluegojnr
posted on 14/4/11 at 08:05 PM Reply With Quote
With the engine swap all done, i've got a CVH engine to sell on.
I don't know an awful lot about it. When it came out of the car it was running good oil pressure, pulled strong, with no nasty knocks or rattles. I was told when i bought it that it had a performance cam, but have nothing to verify this. there is a vernier style timing wheel on the cam. The sump has been shortened and widened. there is a 1/8npt hole for an oil temp sender.
It comes with a 'Flame thrower' coil, and a dizzy converted with some kind of magnetic ignition module thing.
I can also supply engine mounts to fit it to a striker chassis, or similar.
No idea what its worth, £100? tell me if im way off. otherwise make me an offer. Just to confirm, its just the engine with dizzy and coil, no manifolds, carbs etc.
CVH inlet manifold. Nice bit of kit, polished inside. quite short, gap in between port two and three for linkage to fit into - £30 top one in the picture.
More pics on request for either.
Norfolkluegojnr
posted on 16/4/11 at 05:12 PM Reply With Quote
thought i'd mention i've got a fe pallets, so could pallet it up for a buyer/courier
