Author: Subject: Garage clear out.
paulf
posted on 19/5/11 at 12:59 PM Reply With Quote
Garage clear out.
I'm having a clear out and have found the following that may be of use before E bay.All prices plus postage or prefer collection for larger parts, photos in my archive .
Steering wheel adapter fits escort or fiesta column and may also be ok on a Sierra the taper is the same but steering lock was different if I remember correctly £10
200 SX in tank pump condition unknown although did run when i connected 12v to it £5
Zetec silver top coil and leads £10 sold
Coil springs 8 inch 2.25dia 450lbs £15 pair
Fire blade 893 rad no leaks but could do with a clean and paint £15
Air filter unused £8
Malpassi filter king filter reg for carbs needs new element £10 sold
Edis 4, 1 available £10 each 2 sold
Edis 6 1 available £20 each
A couple of ford TPS units with a connector plug and short cable £7 sold
Webber 32 dft jetted for 1600 x flow believed to be from a mk1 xr2 ran well on my gt spec engine £20
A cross flow head complete with modded rocker cover and rockers good condition standard spec. £20
A pair of Sierra rear calipers and Mk3 escort disks suitable for rear disk conversion to axle rusty but would clean up ok £25 Sold
!800 silvertop zetec water pump god condition suit 2 litre conversion £8
Pair of 1.75 SUs £15
Mgb stage 3 cam aeh 770 some surface rust but would be ok if on a budget £15
Robin hood screen, square section frame with Bs marked glass no rubbers plus wiper motor assembly and side brackets, was 2 wide for y book spec car may suit haynes etc £25
A pair of dellorto 40s ex alpha 2 litre need a good clean and the accell pump linkage is broken on one of them could be ok for spares or throttle body conversion. £25 Sold
U2U if interested in anything ,
Paul
[Edited on 19/5/11 by paulf]
[Edited on 20/5/11 by paulf]
Daddylonglegs
posted on 19/5/11 at 01:26 PM Reply With Quote
I'll take the coil and leads for the zetec please
mcerd1
posted on 19/5/11 at 01:45 PM Reply With Quote
u2u sent
djtom
posted on 19/5/11 at 02:47 PM Reply With Quote
I'll take the dellortos and the 450lb springs please.
U2U sent
Tom
madrallysport
posted on 19/5/11 at 03:17 PM Reply With Quote
u2u sent re screen
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
carlknight1982
posted on 19/5/11 at 03:22 PM Reply With Quote
2nd dibs on delautos and screen should it fall through
Edit
Are the Tps 2 or 3 pin?
Carl
[Edited on 19/5/11 by carlknight1982]
Logic will get you from a A to B
Imagination will take you everywhere.
paulf
posted on 19/5/11 at 07:06 PM Reply With Quote
TPS are 3 pin standard ford work with megajolt and megasquirt etc.
Edit
Carl
paulf
posted on 19/5/11 at 07:18 PM Reply With Quote
Forgot to put the Diameter of springs they are 2.25 inch yours if suitable.
Paul
U2U sent
Tom
paulf
posted on 25/5/11 at 11:37 AM Reply With Quote
A few parts still left if of interest to anyone.
Paul
Mal
posted on 6/7/11 at 09:54 PM Reply With Quote
You have a U2U about SU's.
Mal
Gari
posted on 26/11/11 at 09:11 AM Reply With Quote
U2U sent about Edis-4
Hopefully not too late
Gari
speedstar
posted on 26/11/11 at 02:01 PM Reply With Quote
Need an edis for a 2.0 blacktop zetec. Got any left?
spiderman
posted on 26/11/11 at 02:39 PM Reply With Quote
u2u sent re su's
Spider
locost47
posted on 26/11/11 at 03:02 PM Reply With Quote
crossflow head
Hi is the head standard or the larger valve type cheers tim
paulf
posted on 26/11/11 at 03:32 PM Reply With Quote
It is a standard crossflow head as fitted to 1300 and 1600 engines not the GT type.
paulf
paulf
posted on 26/11/11 at 03:34 PM Reply With Quote
I have at least one left maybe 2 will look latter.
Paul
Gari
spiderman
posted on 26/11/11 at 04:14 PM Reply With Quote
Hi Paul
Interested in the SU's if you still have them.
All the best.
Spider
matty h
posted on 27/11/11 at 06:39 PM Reply With Quote
Is the screen still available if so could you give me some dimensions.
Thanks Matty
