nitro cars for sale
Hi all
I have 2 nitro cars for sale
1st, Kyosho DMT monster truck
Features
Full Time 4WD - The full-time 4WD chassis incorporates all of Kyosho’s formidable resources and know-how in the development of this low center of
gravity shaft-driven 3-differential drive train.
GXR18 SP – The DMT is equipped with a brand new .18 engine with a large cylinder head for better displacement and a hi-torque tune pipe and muffler
set for better power output.
Interchangeable - Ball connected suspension features interchangeable suspension arms, front-rear knuckles and shock stays for optimal parts
utilization and maintenance efficiency.
Double Wishbone Sus. - Double wishbone 4-wheel independent suspension with long span arms delivers excellent handling from paved to off-road surfaces.
High Grip Tires - High grip tires and the same wheels proven on the INFERNO ST-RR allow you to dominate any running surface. The wheels are also
compatible with a wide variety of after market tires.
Big Bore Shocks - Features heavy duty big bore oil shocks as standard. Takes even the harshest punishment for long periods without complaint and
provides excellent damping power.
Pre Painted Body - Pre-painted so you can enjoy the action in true truck style without delay.
HD Ring & Pinion - Precision machine cut diff ring gear provides extra strength and hardness.
Multipoint Adjustments - Design features multi-point setting adjustments such as chassis height, camber, tread, front and rear toe-in etc.
Shaft Drive - The drive shafts run through the center for chassis to give you better lower CG and optimum weight balance.
New Steering Layout - The DMT VE has a whole new steering layout which gives you greater response and much more of a steering angle.
103cc – A large capacity 103cc fuel tank supplies the .18 size engine with plenty of fuel and delivers run times of about 8-10 minutes.
Dust Proof - Equipped with dust proof radio box that not only protects the receiver and batteries etc. but also contributes to chassis rigidity.
Easy TLC - Maintenance-friendly design enables easy removal and reassembly of radio box, transmission, engine and suspension shafts etc.
Contents:
Pre-Assembled Chassis
Pre-Painted Body
Perfex KT-200 2.4GHz Transmitter
[img]http://
[/img]
[img]
[/img]
[img]http://
[/img]
[img]http://
[/img]
[img]http://
[/img]
Just add fuel and batterys and your ready to race
£215 inc postage uk only
2nd one is a kyosho inferno neo race spec buggy
This car is ready to to race stright out the box with the pros
Features
Syncro - A Stylish FHSS 2.4GHz RC system featuring dual rate function all pre-installed in the NEO. Also features a 4 channel receiver, providing a
wide range of upgrades.
NEO - Based on the Inferno NEO with a racing specification chassis to match the power of the new engine.
Tunes Muffler - A rear exhaust tuned muffler with hard polish finish and spring connected manifold are included as standard equipment. Giving you the
best performance from the .25 KE engine you can get.
High Torque - Equipped with a high torque KS-102BK servo for the best performance right out of the box.
New Threaded Big-Bore Shocks - Features heavy duty big bore oil shocks as standard. Takes even the harshest punishment for long periods without
complaint and provides excellent damping power. Strong 3.5mm Big Bore Shocks deliver smooth and effective damping for sure-footed performance on a
wide range of surfaces.
Large Diameter Wheels - The new Inferno NEO comes equipped with the same strong wheels as the MP9 competition kit.
New Kyosho Tires - New micro-square pattern tires are pre-mounted giving you full traction on a wide range of surfaces.
New Super Air Flow Body - Includes a new factory-painted body that efficiently channels airflow for greatest aerodynamic effect.
Flexibility & Rigidity - Composite torque rods on front and rear deliver optimal flexibility and rigidity along the chassis and increase the
effectiveness of the suspension for greater traction and consistent handling.
Hard Anodized - The main chassis, upper and front upper chassis plates and the engine head are anodized in black for added strength and surface
hardness giving all your components a longer lifespan.
Blue 17mm Hubs - New Anodized Blue17mm wheel hubs. Now you can use all standard 17 mm wheels.
Endless Adjustments - The suspension and steering linkages feature turnbuckles, which allows for quick adjustments to the camber and steering toe
angles. All that's needed is a 5.5mm wrench to make any adjustment on the spot - there's no need to detach or move anything to facilitate
an adjustment
Full Ball Bearings - Full ball bearings throughout for maximum efficiency through the drive system.
Tough Buggy - Factory-assembled chassis shares the same tough characteristics and low center of gravity as the World Championship winning Inferno 7.5
4WD - Shaft-driven 4WD chassis with three differentials.
Clutch System - New 2-piece clutch realizes efficient power transfer and full adjustability by changing your springs (spring rate) you can control all
aspects of your clutch.
Universal Swing Shafts - Equipped with Front Universal Swing Shafts for more of an efficient drive train.
125cc. Fuel Tank - 125cc fuel tank delivers long run times for even more dirt action
Just add fuel, batterys and off you go.
£260 inc postage uk only
If a little hammer won't fix it get a bigger hammer
